It is currently Mon Jul 21, 2025 2:06 am
PostPosted: Thu Feb 03, 2005 11:18 am
Ok, I've got it in my grubby little hands. The back and side purfling scheme is maple/black/koa. I noticed that the rosette uses white rather than maple. Would you guys rather see white used on the top purfling or maple? I can't decide. P
PostPosted: Thu Feb 03, 2005 12:11 pm
Tough call, YOU'RE the MAN! Put 'em both up there, squint, consternate, then, grab one and glue it....
PostPosted: Thu Feb 03, 2005 12:58 pm
I think white will connect the look of the top better, and as long as the back and sides are the same I think it will look fine.
my .02 worth....
PostPosted: Thu Feb 03, 2005 1:27 pm
I have to agree with Brock.
PostPosted: Thu Feb 03, 2005 1:41 pm
Brock, do you mean that as long as the back and sides are the same as each other or the same as the top? I had Don do the center strip in Maple because I didn't know what the rosette was. I think if I use white on the top and maple on the back and sides it will be all good.
PostPosted: Thu Feb 03, 2005 2:14 pm
Paul, did you get the end graft ok? Don W38386.9270949074
PostPosted: Thu Feb 03, 2005 3:58 pm
Yes. I meant white on the top ledge so the rosette and the top purfling ties. The purfling under the binding on the sides seems less critical that it matches the top.
PostPosted: Fri Feb 04, 2005 12:26 am
Don, no I didn't. Was it in the box or coming from someone else. Paul
PostPosted: Fri Feb 04, 2005 1:06 am
Paul, it's in a plastic bag inside the guitar....
